2394329_en-US
2394329_en-US
2394329_en-US
HSE return "HSE_SRV_RSP_INVALID_PARAM" when request for HMAC verify job
Hello Nxp team,
I have use case to use HMAC verify job. After triggering the job crypto driver throw DET and the response from HSE is "HSE_SRV_RSP_INVALID_PARAM".
I am not able to understand what wrong with my current configuration. could you please check attached config zip file?
Need support to resolve issue.
Aditya
Re: HSE return "HSE_SRV_RSP_INVALID_PARAM" when request for HMAC verify job
Hi @lukaszadrapa ,
Details:
Device: S32K311
HSE FW: HSE_FW_S32K311_0_2_55_0
RTD: SW32K3_S32M27x_RTD_R21-11_6.0.0_QLP01
Aditya
Hi @WagdeoA
Could you confirm which device, which RTD and which HSE firmware version you have?
Lukas
Hi @WagdeoA
There’s no problem in your configuration.
It works on my side. But one possible issue could be the length of tag (secondaryInputLength).
This can be found in function Crypto_Ipw_HmacVerify:
If redirection is disabled, it’s necessary to provide the length of tag in bits, not in bytes. Isn’t this the problem?
Lukas
Re: HSE return "HSE_SRV_RSP_INVALID_PARAM" when request for HMAC verify jobHi Lukas,
Sorry for late reply.
Yes, with length of tag in bits. It works at myside as well.
Thank you!
Aditya
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-22-2026 02:27 AM
更新者:
