2393953_en-US
2393953_en-US
2393953_en-US
s32k 148 Led Blinking example code
Hi, I am using the S32K148 LED blinking example code, but I am facing an issue while debugging it. I will share a screenshot of the error. Please check it and let me know the possible reason and what changes are required in the code.
Re: s32k 148 Led Blinking example code
I didn't encounter this problem when debugging the ftm_periodic_interrupt_s32k148 project of S32K1 SDK RTM 4.0.3 in S32DS v3.4.
Please tell me how to reproduce this problem, such as what modifications you made. If convenient, please upload the modified program so I can quickly troubleshoot the cause on S32K148EVB.
Robin
タグ(1)
評価なし
バージョン履歴
最終更新日:
1ヶ月前
更新者:
