2393034_en-US
2393034_en-US
2393034_en-US
#S32K312 IO input config
I want to used LPUART0 RX,need config IMCR[699],but spec only IMCR[473],So ,what should I do ?
Re: #S32K312 IO input config
Hi @joshua9264
It is noted in Section 10.1.2 of the S32K3xx Reference Manual, Rev. 12, that:
"IMCRs defined in the attached IOMUX file have an offset of 512 with respect to the IMCR number defined in SIUL2 memory map section."
To help clarify how the offset is applied, an example is also provided in Section 4.4.3 of the RM.
BR, VaneB
Re: #S32K312 IO input configyes,I found it. thank you
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-14-2026 03:31 AM
更新者:
