2392466_en-US
2392466_en-US
2392466_en-US
Alternative part for NVT4857UKAZ
This is less directly software related, but we recently discovered that the NVT4857UKAZ has already reached EOL, and there are no pin-to-pin compatible replacement parts available. Since SD card support is a required feature for our i.MX95-based device, we're trying to understand what alternative solutions are available given this situation. Could you share your recommendations on possible replacement options or design approaches?
Re: Alternative part for NVT4857UKAZ
Hello!
You can refer NVT4858 as a replacement.
However, please note that NVT4858 is not a drop-in replacement. Therefore, both hardware and software modifications may be required to accommodate the new device in your application.
We recommend carefully reviewing the specifications and design requirements to evaluate the impact of the migration.
Hope this helps!
Hello!
Hope this helps!
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-09-2026 03:32 AM
更新者:
