2392081_en-US
2392081_en-US
2392081_en-US
pn7220 antenna current
Hello, could you advise how to configure the NFC antenna current for PN7220 via libnfc-nxp-rfExt.conf or other configuration files? Our tests show the antenna current is too high and needs to be reduced.
Re: pn7220 antenna current
Hello @zhangkai
Recommends to enable DPC , but before enable DPC,which needs to be  calibrated.
Hello @zhangkai ,
If you only need to reduce/limit the current, you can do it in the same way as described here: https://community.nxp.com/t5/NFC-Knowledge-Base/PN7642-Basic-RF-power-limitation-using-DPC/ta-p/2187...
TOma
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-10-2026 02:31 AM
更新者:
