2391299_en-US
2391299_en-US
2391299_en-US
implementing I2c on the sci system on an MC9S12X256 16 BIT
The MC9S12XS256 microcontroller does not have a dedicated I2C port, But can the SCI subsystem be used to communicate with I2c displays or similar accessories?
Re: implementing I2c on the sci system on an MC9S12X256 16 BIT
I2C can not communicate withSCI/LIN directly since they are different hardware pin defination.
You may need to use a gateway to transfer the protocol if I2C is must with MC9S12
Hi @fluffyflex,
It can only be emulated using GPIOs:
https://www.nxp.com/docs/en/application-note/AN5264.pdf
https://www.nxp.com/docs/en/application-note-software/AN5264SW.zip
Thank you for that information!, I will utilize that to incorporate a simulated I2C.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-10-2026 02:30 AM
更新者:
