2390072_en-US
2390072_en-US
2390072_en-US
Newbie setting up an autosar environment
When downloading S32 Design Studio for ARM 2.2 – Windows/Linux, the above message appears.
Hopefully, the official website can be reset so that downloads can proceed normally. Thank you.
When downloading S32 Design Studio for ARM 2.2 – Windows/Linux, the above message appears. Hopefully, the official website can reset this so that the download can proceed normally. Thank you.
Re: 新手搭载autosar环境
Please try it now. It should be working.
Peter
S32K新手搭载autosar环境
Thank you very much, teacher. The first problem is solved. However, when installing the S32DS_ARM_Win32_v2.2.exe integrated development environment, an activation failure message appeared. The cause was found to be an expired Activation Code. Therefore, I am requesting an extension. Thank you.
新手搭载autosar环境
Thank you very much for the teacher's support. The environment has been set up.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-19-2026 02:26 AM
更新者:
