2388728_en-US
2388728_en-US
2388728_en-US
SPDT Limit switch interfacing with S32k144 board
I am interfacing an SPDT limit switch ME8112 with the S32K144 board. The code runs, but I am not seeing any value change in the real-time expression window.
I am unsure if this is a hardware connection issue or a GPIO configuration problem.
Could anyone suggest possible causes or debugging steps?
Re: SPDT Limit switch interfacing with S32k144 board
Hi@Turtledove
In your program, the variables you defined are temporary variables. You could try defining them as global variables and then try again.
No ratings
Version history
Last update:
‎07-02-2026 02:36 AM
Updated by:
