2387351_en-US
2387351_en-US
2387351_en-US
MPC5748G: MachineCheck exception hen trying to access peripherals in user mode
I ported OpenPicoRTOS to PowerPC platforms & ran into an issue.
Despite configuring the PBRIDGE (correctly ?) i get a MachineCheck exception every time i try to access a peripheral in user mode.
Supervisor mode works fine but it's not really what i'm after, i want user/supervisor mode management (+MPU) & being able to access peripherals in user mode.
I tried various things but nothing seems to work, i don't know if i'm doing something wrong of it it's simply not possible.
Right now i just kept everything in supervisor mode for demonstration purposes, here's the current state of the code:
 - My attempt at configuring the PBRIDGE:
https://github.com/jnaulet/OpenPicoRTOS/blob/v1.11.x/arch/powerpc/e200z4/mach-mpc574x/startup.S
 - The de-activated user mode (in arch_save_first_context):
https://github.com/jnaulet/OpenPicoRTOS/blob/v1.11.x/arch/powerpc/e200z4/picoRTOS_portasm.S
 - The complete demo i use for debugging this system:
https://github.com/jnaulet/OpenPicoRTOS/tree/v1.11.x/demo/devkit-mpc5748g
Any help is appreciated.
Kind regards.
Re: MPC5748G: MachineCheck exception hen trying to access peripherals in user mode
there can be multiple reasons for user mode access rejection:
Most probably PBRIDGE or MPU configuration.
You can start checking following:
  1. PBRIDGE PACR/OPACR initialization.
  2. Whether all peripheral slots are configured for user access.
  3. MPU region definitions covering:
    • 0xFxxxxxxx peripheral space
    • read/write permissions
    • supervisor/user attributes.
  4. MSR value after the RTOS drops to user mode.
  5. The exact peripheral address that causes the fault.
  6. MCSR/ESR/DEAR at IVOR1 entry.
Peter
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎07-01-2026 03:29 AM
更新者:
