2386239_en-US
2386239_en-US
2386239_en-US
Can't find pin configuration tool for FRDM MCX A266
Can't find on site pin configuration tool.
FRDM-TrainingRe: Can't find pin configuration tool for FRDM MCX A266
This is some helpful information if you are starting with the tool
Quick Start Guide for MCUXpresso Config Tools
MCUXpresso Config Tools User's Guide (IDE)
If there is information or tools that you need to look for, let us know
Best Regards, Luis
Re: Can't find pin configuration tool for FRDM MCX A266Found https://www.nxp.com/design/design-center/software/development-software/mcuxpresso-software-and-tools...Re: Can't find pin configuration tool for FRDM MCX A266
Thanks for your reply.
Will glad if you could point me to howto step by step configuration examples of those tools if possible.
It would depend on what are you trying to achieve, if you could confirm or describe what process do you need assistant for?
Also, the User guide MCUXpresso Config Tools User's Guide (IDE) Chapter 3 is Pin Configuration Instructions with steps and photos that can redirect you to the tool functionalities and match your configuration.
Best Regards, Luis
Yes, please. What I'm trying to do is something simple at this point.
Define 4 DAC and 4 ADC channels.
Route them to the 4 ADC channels internally to close the loop.
Test that those signals arrived, then multiply the number of inputs.
Multiply again and measure performance.
Define log prints to serial over USB for debugging and results presentation.
No ratings
Version history
Last update:
‎07-15-2026 04:30 AM
Updated by:
