I downloaded RPA Tool and updated the information. Here is the snapshot attached.
With the script I was able to get the PMIC information in debug.
here are the debug log and .ds file for reference.
I found out in the debug log the memory capacity was shown as :
Density per chip select: 4096MB
Density per controller is: 4096MB
but I have used LPDDR4 RAM with 1GB capacity (W66DP2RQQAGJ: Dual-Die-Package (DDP) 32Mb x 16DQ x 8-banks x 2 channels with 8 Gb (8,589,934,592 bits) density.
Also it got stuck in "Step 1: DDRPHY Training"
hi, I am getting the same issue with Config tool. Here are the log for reference.
I do not see issues in your configuration for that memory.
Do you get the same issue if you try with DDR Tool of Config Tools?
Best regards.
The issue you are getting in Config Tools shows that there is an issue with serial port connection, please confirm that is connected to the Cortex-A console and the board in serial download mode.
Could you please share you schematic?
Best regards.
The issue is resolved using MSCALE_DDR_TOOL.
Here is the link of the page for IMX8MP
And RPA Sheet Link for LPDDR
