2385474_en-US
2385474_en-US
2385474_en-US
How to install S32K344 A/B swap HSE FW using PeMicro debugger on S32K3x4EVB-T172 (S32K344).
I want to test an OTA A/B swap demo on S32K344.
For that i'll have to install HSE (A/B) firmware on my S32K344 chip which is not having any HSE FW on it.
I have following hardware with me
1. S32K3x4EVB-T172 (S32K344)
2. PeMicro Debugger.
(Note - I dont have Lauterbach TRACE32 tool )
So i request you to please provide me a proper procedure to install HSE (A/B) firmware on s32k344 using PE micro debugger with the help of S32 design studio.
Please try to provide me a proper procedure where everything is mentioned like which DS version, RTD, HSE pink file etc to be used.
Thanks.
Re: How to install S32K344 A/B swap HSE FW using PeMicro debugger on S32K3x4EVB-T172 (S32K344).
HSE DEMO code (that can be downloaded with HSE FW) use Lauterbach TRACE32. There is not dedicated examples using different debugger, but there is HSE examples package:
https://www.nxp.com/webapp/Download?colCode=S32K3_HSE_DemoExamples
It is basically the same functionality as HSE DEMO ported to the code which is debugger independent. For instance if you use S32K344_HSE_FW_INSTALL, you may install HSE FW with using of any debugger.
标记 (1)
无评分
版本历史
最后更新:
‎06-25-2026 02:33 AM
更新人:
