2385176_en-US
2385176_en-US
2385176_en-US
LLM Edge Studio - Qwen2.5-Coder-1.5B not supported out-of-the-box
Applies to: LLM Edge Studio Go Point Demo
Workaround: Requires custom llm_params configuration
The model Qwen2.5-Coder-1.5B is not supported out-of-the-box in LLM Edge Studio using the default configuration. The model loading will fail when attempting to run the model with the default server_config.json
fix: update the llm_params section in server_config.json with compatible sampling values:
- Open config file:
vi llm-edge-studio/usr/share/llm-edge-studio/server_config.json
Replace the parameters as follows:
"llm_params": {
-    "temperature": 0.0,
-    "top_k": 0,
-    "top_p": 0.0,
+    "temperature": 1.0,
+    "top_k": 50,
+    "top_p": 0.95
Qwen2.5-Coder-1.5B should run with proper output quality and sampling behavior after applying the updated configuration.
Remarks:
  • This configuration enables proper behavior for Qwen2.5-Coder-1.5B
  • It may generate warning messages when running Qwen2.5-Instruct-7B, but the model will continue to function normally
BR,
ARA240DNPU
No ratings
Version history
Last update:
‎06-23-2026 08:34 AM
Updated by:
