2385166_en-US
2385166_en-US
2385166_en-US
VLM Edge Studio Demo – Qwen‑VL Initialization Failure
Applies to: VLM Edge Studio Demo using Qwen‑VL backend
Workaround: Apply the attached apply_qwenvl_fix.sh script
In the current VLM Edge Studio Demo, users may encounter a runtime failure when starting the Qwen‑VL Vision Language Model. The issue is caused by incorrect processor initialization, where the code attempts to load tokenizer and image processor assets directly from a hard‑coded Hugging Face model reference instead of the locally deployed tokenizer path.
This typically manifests as:
  • Model startup failures
  • Tokenizer / processor load errors
  • Inconsistent behavior when running in offline environments
To fix no configuration changes are required, copy and apply the provided patch on the board:
root@imx95evk:~# chmod a+x apply_qwenvl_fix.sh
root@imx95evk:~# sh apply_qwenvl_fix.sh
remarks: please make sure the path in the script match your installation:
PROD_FILE="/usr/share/eiq/aaf-connector/venv/lib/python3.13/site-packages/eiq_aaf_connector/llm_engines/QwenVL.py"
ARA240DNPU
No ratings
Version history
Last update:
‎06-23-2026 08:34 AM
Updated by:
