2383715_en-US
2383715_en-US
2383715_en-US
The created control displays incorrectly after being aligned to the center. The simulated position also appears incorrect.
Below the screen, I created a TabView. Tab1 contains a chart. Currently, if I manually align it, the simulated screen appears to be off-center to the right. However, if I use the program's center and bottom alignment options, it results in an image upload error. All of these are incorrect.
回复: 创建的控件位置在对齐局中后,出现显示不正常。模拟出来的位置也不正常的情况
Hi @qujun
I tested it on my end.
I did not reproduce the issue you mentioned. Which version are you using? How to reproduce this problem?
Harry
标记 (1)
无评分
版本历史
最后更新:
‎06-24-2026 03:28 AM
更新人:
