2383344_en-US
2383344_en-US
2383344_en-US
S32K344 SWT reset
Hello ,
I am trying to understand the SWT functionality.
I injected stackoverflow to check how SWT reset the controller. Reset happening properly. Reset reason also match with SWT.
when i continously trigger stackoverflow error, After 8 times, controller does not power up.
I check many times, it working exactly 8 times only, is there any specific reason? or is it configurable?
Re: S32K344 SWT reset
Hi @nirmal_masilamani
This is caused by reset escalation feature. Take a look at following sections in the reference manual or just search for “reset escalation” keyword in the document for more details:
33.7.7 Functional reset escalation
33.7.8 Destructive reset escalation
It can be disabled by FRET and DRET registers in MC_RGM module.
Lukas
Hello @lukaszadrapa
Thank you for your response.
I understood that by changing FRET and DRET, we can cfg reset escalation. In Power module there is a parameter for that.
If I keep zero in both, i am able to disable escalation but, if I change the counter between 1 to 15, its not reflecting. Still SWT working only for 8 times.
No ratings
Version history
Last update:
‎06-23-2026 02:28 AM
Updated by:
