2382805_en-US
2382805_en-US
2382805_en-US
When configuring the S32K311 chip's UART, even with simple transmit functions, the control board needs to be powered off and then powered on again each time for it to transmit correctly.
When configuring the S32K311 chip's UART, the simple send function requires power cycling through the control board each time it needs to send data correctly. Using the Lpuart_Uart_Ip_AsyncSend function for sending data is preferable.
Re: S32K311芯片 在配置uart时,简单的发送函数,每次都需要给控制板断电重新上电才能正常发送
Hi@ Finnc
Share your project details, and I'll check it for you.
Please tell me the hardware you are using. If it is not an official EVB, please tell me the frequency of your external crystal oscillator.
Hi@ Finnc
I checked the project you provided and tested it; it works fine on my end.
Software version S32DS 3.6.0 RTD 6.0.0, external crystal oscillator 20MHz
No ratings
Version history
Last update:
‎06-23-2026 02:36 AM
Updated by:
