2376371_en-US
2376371_en-US
2376371_en-US
33774 Voltage Measurement
The 33774 has 18 channels and uses 16 channels, with channels 17 and 18 shorted to channel 16. When measuring, the measured value is abnormal when the low voltage of channel 15 and 16 is 0.3v or less, channel 15 measured value is high, and channel 16 measured value is low. How should it be solved. #mc33774
Re: 33774电压测量
For this product support I suggest you sign up with your company's email and submit the ticket.
Home
Need to check the schematic and then troubleshoot step by step
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎06-05-2026 03:30 AM
更新者:
