2368490_en-US
2368490_en-US
2368490_en-US
S32K312 RTD [SW32K3_S32M27x_RTD_R21-11_5.0.0]
Dear Sir/Madam,
We are using S32k312 Mini Eval board for our application development.
Planning to use SW32K3_S32M27x_RTD_R21-11_5.0.0 or SW32K3_S32M27x_RTD_R23-11_7.0.0 . Is it any NDA agreement need to be signed to use this RTD?
S32K design studio [S32DS.3.6.6] configuration tool used for configuration file generation. Since it is open source using for configuration file generation, but IAR used for compilation & debugging. NDA needed for configuration use?
Please support.
Thanks & Regards,
Thalapushpam
Re: S32K312 RTD [SW32K3_S32M27x_RTD_R21-11_5.0.0]
Hi @Thalapushpam1
There is no need for an NDA to access or use RTD, and the same applies to S32DS. However, it is important to review the license agreement to understand the terms of use.
Regarding IAR, S32DS provides support through an IAR plugin that allows you to use the IAR compiler. However, you will still need a valid license from IAR to use it. For more details about licensing or usage, it is recommended to contact IAR directly.
BR, VaneB
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎05-21-2026 03:31 AM
更新者:
