In a few months at my company we will have our new SoMs (built on the top of NXP LS1028 SoC) ready to bring-up. That's way I would to get some knowledge from you - more experienced developer - how do you approach DDR bring-up? What tools do use use? How do you perform DDR initialization? What steps do you perform? What are the common pitfalls regarding DDR bring up? What should I be aware of?
For the DDR validation, please kindly follow the QCVS_DDR_User_Guide.
After successfully finishing the QCVS validation, clicke the icon of "Generate processor expert code" to generate the optimal timing pararamers in
The QCVS DDR is one tool of codewarrior Developer Suite Level.
You can also download codewarrior Developer Suite Level Evaluation Edition from the link below.
The Evaluation Edition is free to use but has a time limitation.
The debug tool is used to connect the LS1028A customer board and the codewarrior Developer Suite Level, please kindly find the tool in below link:
https://www.nxp.com/design/design-center/development-boards-and-designs/CW_TAP
CodeWarrior TAP High Performance Probe Base unit, supports Ethernet and USB (order tip separately).
Layerscape processor (Coretex 10 pin)
The DDR layout should follow the AN5097
AN5097, Hardware and Layout Design Considerations for DDR4 SDRAM Memory Interfaces
