Hi. I got a problem with MC33774A. I enable cyclic periodic measurements with balpause ( writing 3 to MC33774_ALLM_CFG_OFFSET ). It seems that this is only working when i'm balancing even cells. when balancing is enabled on odd cells then cyclic measurements shifts for those cells. sometimes less than expected sometimes more. what could be the problem?
Alternatively - how can i setup MC33774A to cyclic mode - so it sleeps, measures, sleeps?
If i try to write 2 to SYS_CYC_WAKEUP_CFG and then 10 to SYS_MODE device still goes to deep sleep instead.
Hello andis_bankovics
Good day!
I'm reviewing your case. I'll get back to you as soon as I have an answer.
Have a great day and best of luck.
