2365554_en-US
2365554_en-US
2365554_en-US
S32DS S32K144 SDK install fail
Re: S32DS S32K144 SDK install failOK,thank youRe: S32DS S32K144 SDK install fail
Hi @joshua9264
The S32 Software Development Kit (SDK) for S32K1 is no longer supported in the newer S32DS versions.
If you still need to work with this SDK version, please note that it is already bundled with S32DS v3.4,, it is recommended to use the same IDE version in which the software was originally developed and tested, as this helps avoid potential compatibility issues and simplifies the setup process.
BR, VaneB
Where to download S32DS v3.4?
In the download page S32 Design Studio IDE for Arm based MCUs | NXP Semiconductors
There's only java type foldes with no .exe
Please advice
タグ(1)
評価なし
バージョン履歴
最終更新日:
17 時間前
更新者:
