2364598_en-US
2364598_en-US
2364598_en-US
RT1052 development board SDK adapted to Keil development environment issues
NXP Technical Support:
Hello!
As shown in the above figure, when downloading the SDK for RT1052 development board, there is a prompt "If you use KEIL development environment, it is recommended to use version 2.8.2 of the SDK". Does it mean that the SDK after version 2.9 is not recommended to use KEIL development environment?
--- Is my understanding of the above incorrect? I would be grateful for any help in confirming this.
(used at the end of a letter introduce a polite salutation)
Salute!
Re: RT1052开发板SDK适应Keil开发环境问题
Hi @FromCH0,
Thank you for your interest in the NXP RT family of products and we are pleased to be of service to you.
I apologize for the confusion.
We have confirmed internally that it is not the case that Keil is not supported in the new version, but rather that Keil engineering support is not available in the specific version 2.8.5, hence the special message in that version.
Keil is still supported in 2.9 and later versions of the SDK and can be used normally.
I hope you find the above instructions helpful.
Best Regards
May Liu
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎05-14-2026 04:31 AM
更新者:
