Hello NXP Team,
We are designing a Hardware platform using the MIMX8ML6NKZACVB Processor.
Can you please share the power dissipation value for this processor?
Thank you for your interest in NXP Semiconductor products,
The part number misses some parameters for its differentiation. It misses if it's industrial or automotive.
However, both packages have a thermal resistance of the following, it depends on every customer to take the thermal resistance, environmental and processing load conditions to select an specific part.
As a suggestion, you could use the NXP EVK heatsink part:
Name: HEAT SINK 40*40*15MM, BLACK ALUMINUM
Manufacturer: Suzhou Puqiao Electronic CO.,LTD
Manufacturer part number: NXP-PQ-HS0002
