Activation code for S32 Design Studio 2.2Download S32 Design Studio for ARM v2.2. Only have the activation code for S32 Design Studio for ARM v2.2 Update 2, no activation code for the S32 Design Studio for ARM v2.2 IDE. Installation prompt: Your Software Activation Code is for another feature. Do you want to return it?
回复: Activation code for S32 Design Studio 2.2Have you solved it? I also encountered the same problem.
Re: Activation code for S32 Design Studio 2.2Hi,
please download S32DS v2.2 installer ( without Update 2), run it and activate it again.
If activation still fails, try to backup and delete content of c:\ProgramData\FLEXnet\ and start installation again. The folder is hidden by default.
The activation code is same as for S32DS v2.2 update 2, but there is some issue with this version.
