2350388_en-US
2350388_en-US
2350388_en-US
The RTD version used in FSS FW and FSS AUX sample compatibility
Hello Team,
Software package: SDK_1_0_5_3
Customer: Schaffler
The RTD versions used in the released FSS FW and FSS AUX are not compatible with the expected GrayVIP version, which may cause confusion for customers.
GrayVIP expects version TS_T31D62M28I0R0, while the release currently uses TS_T31D62M18I0R0. As a result, after importing the project and saving it again, significant configuration changes can be observed in IPCF, NETC, and EcuC XDM, beyond the intended version updates. In particular, when customers switch GrayVIP from an older version to this release, code generation may not behave as expected.
Is there a workaround available to resolve this incompatibility in the current release, or can we confirm that the observed changes do not impact code generation or system functionality?
Customers expect that this incompatibility can be avoided in future releases, as it currently leads to unnecessary debugging effort and time loss.
Tangsheng.
FSS_FWGRAY_VIPPriority: MEDIUMRe: The RTD version used in FSS FW and FSS AUX sample compatibility
Hello @Tangsheng_Zhou,
The development teams have picked up the case and will provide an answer as soon as possible.
Radu
Hello @RaduBraga
1. Can we please get a status update here?
2. What is the associated JIRA ticket?
3. Can you confirm a configuration fix will be made for GrayVIP 1.0.6.0 ?
Thanks.
After a discussion with the GrayVIP development team a jira ticket was created for the FSS team.
Hi Radu,
Could you please provide the JIRA ticket link for the FSS ticket you mentioned?
Thanks.
Hello @RaduBraga
Could you please provide the JIRA ticket link for the FSS ticket?
Thanks!
Tangsheng.
Best regards.
No ratings
Version history
Last update:
‎06-09-2026 04:28 AM
Updated by:
