2349453_en-US
2349453_en-US
2349453_en-US
MIMXRT1176 Flash IC
Sir,
 We have design the custom board base on MIMXRT1170-EVK evaluation board.
Our custom board using NOR Flash 128Mb QPI/QSPI, IS25WP128-JBLE,PACKAGE:SOIC-WIDE-8 is not working.We have purchased the IC from distributor.Problem discussed with NXP authorized distributor M/s Avnet  and they arranged IC IS25WP128F-JBLE from OEM ISSI. IC assembled first in MIMXRT1170-EVK and found that IC was not working.
When a replace the IC from Evaluation board , it is working fine.
Request to provide a solution/IC pin to pin replacement as soon soon possible.
Ravi Kant Verma
HAL,HYD,INDIA
Re: MIMXRT1176 Flash IC
Hi @Ravi07011983 ,
Hope you are doing well!
I found that we already have a same case in SFDC. Let's keep sync there. Thanks!
Gavin
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎04-15-2026 05:34 AM
更新者:
