Got hands on the MPC5775B BMS AND VCU REFERENCE DESIGN. Was trying to implement a basic project in it as a starting point.
Saw this in one of the documents I got:
Now do we need both the debugger ? Can we not program this unit with the USB it came with ? Is it absolute necessity to get the CAN adapter too ?
Thanks for the response @petervlna !
Thanks for the mention as I had totally missed out on checking that. So I see now that the USB port given on this unit can be used only for UART communication. Right ?
Looking at the board itself, it does not have any open-SDA uC for programming via USB cable.
You will need standard JTAG programmed / debugger for programming this board.
Peter
