2342082_en-US
2342082_en-US
2342082_en-US
mcu-sdk-cmsis version
In our projects, we use an SDK downloaded manually. We use four repositories: manifest, core, mcux, and cmsis. Currently, we are using version 24.12.00. We want to switch to the newest version, 26.03.00. I see that manifest, core and mcux have release branches for the latest version, but cmsis does not have a release branch for version 26.03.00. Can we use cmsis release version 24.12.00 together with the newer versions of the other repositories?
Re: mcu-sdk-cmsis version
Thank you very much for the quick and reliable response. I hadn't noticed this .yml file earlier.
Andrzej
Hi @AndrzejWo
About the mcx-sdk-cmisis version.
I think you can check mcuxpresso-sdk/manifests/submanifests/base.yml.
  - name: CMSIS
    repo-path: mcu-sdk-cmsis
    path: mcuxsdk/arch/arm/CMSIS
    revision: dc8b75b360fce9c864a12f1ccc54172e0c733805
    groups:
    - core
    - ble_nxp
    userdata:
      track_branch: mcux_main
      branch_flow: false
      display_name: CMSIS
      description: Vendor-independent hardware abstraction layer for microcontrollers
        that are based on Arm Cortex processors, distributed by ARM.
I recommend that you can follow the manifest.
Harry
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎03-31-2026 04:30 AM
更新者:
