Hi Team,
The customer would like to check if S32DS can be installed on Windows Server 2019/2022/2025 and be operated without any issue because they allocate their budge to purchase laptop and, depending on our feedback, they need to change their plan to purchase laptop. So, they want to check it carefully.
In our manual, we just have verified S32DS operation with the below environment.
I couldn't find any ticket about Window Server 2019/2022/2025 compatibility with S32DS installation/operation including packages plug-in.
So, I would like to check if there is no problem with Window Server 2019/2022/2025 and S32DS and expected issue. Also to check if we have some experience.
Could you please check it?
Marco
Hi Jiri,
Thank you for your support!
I will check if the customer has further questions.
Marco
Hi Marco,
S32DS is not tested with MS Windows server. It will be probably working, but there may be some issues.
I never used MS Windows server, but as I understand it, it is regular windows with some additional services and configuration. We can't guarantee that S32DS will be fully operating, but customer can try it and check it on his side.
