2335700_en-US
2335700_en-US
2335700_en-US
S32K142 chip is secure and unable to mass erase
Hello @danielmartynek, & @lukaszadrapa
I am using S32K142 controller for our hardware. We have secured it with FSEC register with MEEN bit enabled. however, unable to perform mass erase with S32k.cmm mentioned in Solved: In s32k118 Cant write FSEC bit Setting using T32 - NXP Community script using lauterbach. when tried system.up command "bus error generated by CPU" is thrown.
When MDM-AP register is read using lauterbach debugger. The value is 0x7F. Can you help me how to perform mass erase?
FYI, debug interface is SWD
Thanks in advance
Re: S32K142 chip is secure and unable to mass erase
Hello @firmsol,
I have posted a new script here:
https://community.nxp.com/t5/S32K-Knowledge-Base/Lauterbach-Script-For-MDM-AP-Mass-erase-S32K142/ta-...
Could you run or step through it on your side?
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎03-20-2026 04:26 AM
更新者:
