I am running QCVS DDR 1D margin test on my board, and I am confused about how this test runs internally. My questions are:
Q1: The 1D margin test sweeps the strobe signal in the data eye for each byte lane. How is it achieved? I don't see any configuration register for adjusting the data eye timing for each byte lane. Is this configuration register reserved and not shown to users?
Q2: Will centering the data eye for each byte lane be automatically done in the DDR initialization flow without any customer register configuration ?
Dear @lingjun ,
Regarding your questions:
Q1. The tool “sweeps the strobe signal in the data eye for each byte lane, using small timing steps”, this sweep happens after the controller has already initialized using its normal internal calibration sequence.
Dear LFGP:
thanks your reply, It really helpful to me.
But in margin test in my board occur another wired question. From QCVS FAQ Guide.pdf the bright green cells means which the controller automatic choose strobe center point. My test result show below, the Lane 0~2 have the bright green cells,but Lane 3 don't have bright green cell.
Q1: Does the controller choose strobe point fall into the failing regions cell and so no bright green shown in Lane3?
Q2: can your give some suggestion how to deal with the Lane3 issue?
thanks very much.
