2327664_en-US
2327664_en-US
2327664_en-US
S32N55 RTD Dio driver limitation
Hi ,
Here is a driver limitation in RTD_DIO_UM(Version-SW32N_RTD_R21-11_1.8.0):
After testing, FSS_GPIO1_19 (FCCU_ERRSTT1) can be toggled by the DIO module in the RTU0 project.
Could you please provide more details regarding this limitation?
Alternatively, is this limitation outdated and should it be removed?
Alex
S32N55 AUTOMOTIVE-RTD
RTDRe: S32N55 RTD Dio driver limitation
Hi @Alex_Liu,
The dev team said that: "this issue is a hardware limitation - TKT0638320. So, they skipped testing process and noted about this limitation in Dio_UM."
From my point of view, to clarify this limitation, you should contact the S32N55 hardware team.
Dan
Hi @DanNguyenDuy
I’ve checked with the colleagues who are familiar with this ticket, and confirmed that the hardware limitation has already been fixed on the B0 sample. You can find more details in the Design PDM.
Since the hardware bug has been resolved, could you please help remove the corresponding limitation description from the DIO UM?
Alex
Hi @Alex_Liu,
Thank you for your information. Unfortunately, I can't access your link. Could you capture information and contact points from hardware team to help me confirm this?
Based on this information, I can raise a ticket to RTD for requesting update Dio_UM file.
Dan
Hi @DanNguyenDuy
I catch the information as below:
It shows you can double check with Rob Rand. Or you can get more details with Rares Vasile, who belongs to FSS software team.
Alex
Hi @Alex_Liu,
I raised a "change request" ticket (ARTDCANG-1641)to RTD team for requesting update about this hardware limitation in Dio_UM.
Dan
No ratings
Version history
Last update:
‎03-13-2026 04:27 AM
Updated by:
