2319255_en-US
2319255_en-US
2319255_en-US
Crypto_43_HSE Driver for S32K3 RTD 7.0.0
I have a S32DS project setup with the following:
  • S32DS IDE: 3.6.4
  • S32K3 RTD: 7.0.0
  • HSE firmware: S32K344 0.2.55.0
  • MCU: S32K44
From my understanding, in order to use HSE firmware, I will need to attach the Crypto driver to my project through the components configuration.
However, when I check my RTD files in "C:\NXP\S32DS.3.6.4\S32DS\software\PlatformSDK_S32K3", the folder "Crypto_43_HSE" does not exist.
Is this driver necessary? If so, where can I find it? If not, what is the recommended way to use HSE firmware?
If it is not available/supported for the latest RTD version at the moment, where can I stay in the loop for new releases/docs?
S32K344-WB S32DS-S32PLATFORM AUTOMOTIVE-RTD
Re: Crypto_43_HSE Driver for S32K3 RTD 7.0.0
Hi @rvthai
Sometimes the Crypto driver is not available in first initial release of new RTD and it is provided later in separate package. You can check section “2.5  Support and Driver Plugins Delivered” in release notes for each package.
In case of RTD 7.0.0, Crypto driver is provided in package 7.0.0 QLP02:
And in release notes of QLP02:
This package should be installed on top of initial release.
Lukas
Hi @lukaszadrapa,
I installed the initial release of RTD 7.0.0 through S32DS Extensions and Updates. I then installed RTD 7.0.0 QLP02 after.
The installation succeeded. However, each time I open my IDE now, I get the following pop-up message. Would you please help me understand what this means and if it is expected?
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎02-27-2026 02:25 AM
更新者:
