2314397_en-US
2314397_en-US
2314397_en-US
K5 Clock_IP definition issue
Hi Team,
For K5 RTD0.8.0, this macro should be zero, not one.
Please confirm and fix it.
Liek
Priority: HIGHRTDSource: NXP InternalRe: K5 Clock_IP definition issue
Hi @LiekLi ,
SW team said that they will provide the fix in the ticket that I mentioned above and they will create another ticket to get confirm from doc team in same time.
Nhi
got it, thanks very much.
Hi @LiekLi ,
This fix should be involved in the next release, right? Because SW team just accept to change code with the information from RM or confirmed by doc team. I will say them to prioritize this ticket. They will provide the fix after getting the confirm from doc team.
Nhi
Hi Nhi,
Thanks very much for your reply. To change the value to zero is tested by local AE team during silicon bring-up.
If you confirmed from SW team, I proposal to create another JIRA ticket to fix it.
Liek
Hi @LiekLi ,
From my point of view, this came from RM not define CTRL[CTRL_CLK_SELECT] to see value 0 or 1 is FXOSC. I didn't find any information relate to this. Except this diagram but still not clear. The ticket ARTDCMCU-691 raised to SW team will ask doc team or you can please help to ask doc team about CTRL_CLK_SELECT.
Nhi
No ratings
Version history
Last update:
‎02-10-2026 02:23 AM
Updated by:
