2305379_en-US
2305379_en-US
2305379_en-US
rw612 config
The configuration tool is too annoying. I am using the RW612. In addition, the SDK is getting worse in newer versions. The configuration tool should generate the correct files in the root directory; although the .mex file exists, it is sometimes generated in a different folder. Overall, all of your tools and SDKs are horrible.
Re: rw612 config
Hello @gtecaskari, hope you are doing well.
I'm sorry to read that you have encountered with some issues. To better analyze your issue could you please share your environment setup? Including your IDE (MCUXpresso IDE or MCUXpresso for VS Code), SDK version, RTOS, and the specific example that you are testing.
Re: rw612 config
Hi. thanks for your answer. I have tried all version, 25.6 -25.9 - 25.12
25.12 is getting worse .
you can just compare it to stm32cubemx and can understand how awful is it.
Re: rw612 config
Hi @gtecaskari.
Feel free to correct me if I'm wrong, but if you are using MCUXpresso for VS Code with Config Tools support, could you please confirm that you have followed the recommended workflow stated at the following page: Working with MCUXpresso Config Tools?
Additionally, it would be very helpful if you share with me the steps that you are following in order to reproduce your issue.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎02-07-2026 03:29 AM
更新者:
