2304867_en-US
2304867_en-US
2304867_en-US
nt3h2111 cannot be accessed via IIC
I encountered an issue while using the NT3H2111 chip. When issue occur, IIC read/write operations always get NAK result , yet NFC read/write operations on the EEPROM function normally.
I attempted to scan all IIC addresses but did not receive any valid ACKs.
After this situation occurred, I had to replace the IC with a new one. Is there a way to check?
Re: nt3h2111 cannot be accessed via IIC
Hello KaiLi
Yes, replacing the chip will fix  communication issue.
When the issue occurred, I used a logic analyzer to capture the actual waveforms of SDA and SCL. I found the IIC waveforms were normal, but there was no ACK when writing to the component address. I performed an I²C address scan, and all addresses returned NAK.
Hello @Jerry_zeng22
So, I'd like to ask if replacing the chip will fix the communication issue?
Also, could you use a logic analyzer to monitor the data on the I2C lines, like SDA and SCL?
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎02-04-2026 03:20 AM
更新者:
