2291369_en-US
2291369_en-US
2291369_en-US
McuPGOOD_POLARITYControl Configuration Error Reported When EB Updates RTD 7.0.0_QLP03
This McuPGOOD_POLARITYControl configuration item is not found under this path
Re: EB更新RTD 7.0.0_QLP03时报告McuPGOOD_POLARITYControl配置错误
Hi@WeiCh
I'm not sure if you can download it, you can try it, if not, contact your agent or FAE for evaluation access.
https://www.nxp.com/design/design-center/software/automotive-software-and-tools/real-time-drivers-rt...
Re: EB更新RTD 7.0.0_QLP03时报告McuPGOOD_POLARITYControl配置错误Where can I download 30.0.0?Will 30.0.0 open a 29.0.0 project?Re: EB更新RTD 7.0.0_QLP03时报告McuPGOOD_POLARITYControl配置错误
Hi@WeiCh
I see that the version of EB Tresos that this version adapts to should be 30.0.0, not the version you are using.
Hi@WeiCh
In the download screen there is this hint that you have to change the suffix
Re: EB更新RTD 7.0.0_QLP03时报告McuPGOOD_POLARITYControl配置错误It's already working, thanks!Re: EB更新RTD 7.0.0_QLP03时报告McuPGOOD_POLARITYControl配置错误
This is the 30.0.0 interface, which still doesn't seem to have this configuration item.
Hi@WeiCh
The style of your interface is not right, the style of the new version is totally different from the old one.
There seems to be a bit of a problem, running setup prompts that there is no installer, you can unzip EBtresosStudio_EBtresosStudio.zip and open the app directly, but the app interface is still old:
Hi@WeiCh
Okay, you're welcome.
No ratings
Version history
Last update:
‎01-14-2026 02:27 AM
Updated by:
