Is the NXP S32R45 Evaluation Board (EVB) compatible with the NXP TEF82XX antenna board in terms of physical connection and functional operation?
The TEF82xx‑CAB is specifically designed to integrate with S32R41-EVB or S32R29-RADB, using dedicated high-speed connectors exposed on those boards.
The S32R45 EVB lacks these connector pairings, so the antenna board cannot be directly attached.
You cannot directly connect a standard TEF82xx antenna board (CAB) to an S32R45 EVB—no matching connectors or compatibility.
If you need to work with TEF82xx transceivers on S32R45, you must use a custom development platform like NovTech's Renan™, which integrates the board hardware, proper RF connectors, and requisite software support.
https://www.issi.com/WW/pdf/NovTech-RENAN-Flyer.pdf
Peter
