2270479_en-US
2270479_en-US
2270479_en-US
Request for TJA1128 driver files and guidance on LIN transceiver and watchdog usage
Hi NXP Support Team,
I am currently working with the TJA1128 LIN Mini System Basis Chip and I am new to this device.
While reviewing the application note AH1801, I noticed that the software example and driver files for TJA1128 are available through NXP DocStore (NDA required). I would like to request access to the example driver source code and reference project for TJA1128.
In addition, I would appreciate some initial guidance on the following points:
  1. LIN Transceiver Verification
    • How to properly bring the TJA1128 into Normal mode for LIN communication
    • Any important initialization or pin/configuration requirements to verify basic LIN TX/RX functionality
  2. Watchdog Handling
    • How the watchdog is expected to be refreshed in Normal mode
    • Any timing constraints or typical watchdog configuration recommendations
My current plan is:
  • First, to verify basic LIN transceiver functionality
  • In parallel, to validate watchdog refresh behavior from the MCU
Any application notes, driver documentation, or best-practice recommendations for these use cases would be very helpful.
Thank you for your support.
Kasirajan C
[email protected]
No ratings
Version history
Last update:
‎01-01-2026 02:27 AM
Updated by:
