2269247_zh-CN
2269247_zh-CN
2269247_zh-CN
FTM 定时器混乱
我试图启动 FTM0/FTM1 定时器,但在运行定时器代码时却出现了 HardFault 故障,为什么?
无法运行的代码
#include "MKE02Z4.h"
/* ================= GLOBALS ================= */
volatile uint8_t uartFlag = 0;
/* ================= PROTOTYPES ================= */
void init_clock(void);
void init_uart0(void);
void init_FTM1(void);
void UART_Send(const char *s);
/* ================= FTM1 ISR ================= */
void FTM1_IRQHandler(void)
    /* Clear overflow flag (write 0 while set) */
    FTM1->SC &= ~FTM_SC_TOF_MASK;
    uartFlag = 1;
/* ================= MAIN ================= */
int main(void)
    init_clock();
    init_uart0();
    init_FTM1();
    UART_Send("FTM1 Initialized\r\n");
    while (1)
        if (uartFlag)
            uartFlag = 0;
            UART_Send("A\r\n");
        __WFI();   /* wait for interrupt */
/* ================= CLOCK INIT ================= */
     * Assume internal clock already configured by SDK startup
     * Bus clock = 32 MHz
    SIM->BUSDIV = 0x01;   /* divide by 1 */
/* ================= UART0 INIT ================= */
    /* Enable UART0 clock */
    SIM->SCGC |= SIM_SCGC_UART0_MASK;
    /* UART0 pin select (TX/RX) */
    SIM->PINSEL |= SIM_PINSEL_UART0PS_MASK;
    /* Disable TX inversion (important!) */
    SIM->SOPT &= ~SIM_SOPT_TXDME_MASK;
     * 9600 baud @ 32 MHz
     * SBR = 32e6 / (16 * 9600) ≈ 208
    UART0->BDH = 0x00;
    UART0->BDL = 53;
    UART0->C1 = 0x00;
    UART0->C2 = UART_C2_TE_MASK | UART_C2_RE_MASK;
/* ================= FTM1 INIT ================= */
    /* Enable FTM1 clock */
    SIM->SCGC |= SIM_SCGC_FTM1_MASK;
    __DSB();
    /* ---- VERY IMPORTANT ORDER (KE02 SAFE) ---- */
    /* Stop counter completely */
    FTM1->SC = 0;
    /* Disable write protection (WRITE ONCE) */
    FTM1->MODE = FTM_MODE_WPDIS_MASK;
    /* Reset counter */
    FTM1->CNTIN = 0;
    FTM1->CNT   = 0;
     * 32 MHz / 128 = 250 kHz
     * 250000 ticks = 1 second
    FTM1->MOD = 249999;
    /* Enable overflow interrupt, prescaler = 128 */
    FTM1->SC = FTM_SC_PS(7) | FTM_SC_TOIE_MASK;
    /* Enable NVIC */
    NVIC_EnableIRQ(FTM1_IRQn);
    /* START TIMER (LAST STEP ONLY) */
    FTM1->SC |= FTM_SC_CLKS(1);
/* ================= UART SEND ================= */
    while (*s)
        while (!(UART0->S1 & UART_S1_TDRE_MASK));
        UART0->D = *s++;
工作代码
void init_FTM2(void);
/* ================= FTM2 ISR ================= */
void FTM2_IRQHandler(void)
    FTM2->SC &= ~FTM_SC_TOF_MASK;
    uartFlag = 1;
int main(void)
    init_clock();
    init_uart0();
    init_FTM2();
    UART_Send("FTM2 Initialized\r\n");
    while (1)
        if (uartFlag)
            uartFlag = 0;
            UART_Send("A\r\n");
    UART0->BDH = 0x00;
    UART0->BDL = 53;
    UART0->C1 = 0x00;
/* ================= FTM2 INIT ================= */
    /* Enable FTM2 clock */
    SIM->SCGC |= SIM_SCGC_FTM2_MASK;
    __DSB();
    FTM2->SC = 0;
    FTM2->MODE = FTM_MODE_WPDIS_MASK;
    /* Reset counter */
    FTM2->CNTIN = 0;
    FTM2->CNT   = 0;
    FTM2->MOD = 249999;
    FTM2->SC = FTM_SC_PS(7) | FTM_SC_TOIE_MASK;
    /* Enable NVIC */
    NVIC_EnableIRQ(FTM2_IRQn);
    FTM2->SC |= FTM_SC_CLKS(1);
    while (*s)
        UART0->D = *s++;
Re: FTM Timer Confusion
你好@Jana_muralidharan
请调试检查 FTM1 时钟是否启用,并验证计数寄存器是否正常工作。
爱丽丝
实际上,我发现了错误
这是因为我使用了仅适用于 FTM2 的寄存器、
因此,在删除不需要的寄存器后,它就能正常工作了。
我发现HardFault Error 只有在以下情况下才会发生、 我们使用了原本不存在的寄存器。
嘿,感谢您对这个问题的关注,谢谢.....。
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎12-30-2025 02:26 AM
更新者:
