2269108_en-US
2269108_en-US
2269108_en-US
Read PHY address (LAN 9646) by Ethernet driver
Hello everyone,
I tried to read the PHY address of LAN 9646 by function Eth_43_GMAC_ReadMii but it return unexpected results. I just want to ask that this function is suitable for reading PHY address. Thanks for reading.
Re: Read PHY address (LAN 9646) by Ethernet driver
yes, the Eth_43_GMAC_ReadMii is a function to read a PHY register over MDIO using clause 22.
It is not clear what parameters you used in function and what reading you get. Be sure you are using right PHY and register addresses as specified in device datasheet for Standard MIIM Registers (Direct) access.
Also be sure MIIM interface is selected, per the device DS it is not a default one, configured by strapping option.
BR, Petr
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎01-03-2026 03:22 AM
更新者:
