I have recently received a new sample of the iMX95 B0, having previously worked with the A1 version. I would appreciate it if you could provide me with details regarding any hardware-related changes or other differences between these two versions.
Could you kindly clarify the specific differences between the iMX95 B0 and A1?
Thank you for your time and assistance.
Hi @Shubham2
B0 fixes numerous internal bugs within the chip, so it affects a wide range of software. I cannot list all specific differences in detail, but I believe that if you use a BSP version L6.12.34 or higher, you need not concern yourself with chip version issues. If you need to migrate the BSP, please perform the porting based on a BSP version L6.12.34 or higher.
Zhiming
So, simply put, this means there are no hardware-related changes between A1 and B0 .
Hi Zhiming,
Where could one find the exact differences between A0, A1 and B0 silicon revisions? We are noticing some issues using latest BSPs on A0, specifically relating to NPU usage.
