2264603_en-US
2264603_en-US
2264603_en-US
s32k312 hse work abnormal when enable gcc -O1
Hi NXP expert,
   1. i am using s32k312 hse to do a rsa verify function,  i store the rsa public key in NVM catalog
{ HSE_ALL_MU_MASK,  HSE_KEY_OWNER_CUST,   HSE_KEY_TYPE_RSA_PUB, 2,  HSE_KEY2048_BITS },
   2. it can verify in default project, which in settings, gcc optimization is  None (-O0)
  3.  i want to shrink the binary size, and change gcc settings to -O1,  no else changed. then the function returns  failed (0x55a5a164)
how to solve this problem
thanks.
Re: s32k312 hse work abnormal when enable gcc -O1
Hi victory,
Based on your description, it sounds very similar to the issue described in the S32K3常见问题检查列表(Check list)-V1.2-20251113.docx:  4.32 编译器优化设置不当导致HSE服务失败问题
Please note that during the Christmas holiday period, our support response times may be longer than usual. In some cases, your request might be addressed after the New Year. Thank you for your understanding.
Robin
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎12-18-2025 03:40 AM
更新者:
