2259684_en-US
2259684_en-US
2259684_en-US
Access GPT capture on imx6ull from user space or module
I am trying to understand if I am able to use GPT2 for input capture (counting sensor pulses) on my custom imx6 board. From the Linux Reference Manual I can read that GPT is used by linux to enter WFI mode, but I have also found sources saying it is fine to use GPT2?
Any help to clear this out would be appreciated, both if it is possible and how I would go about doing it.
Re: Access GPT capture on imx6ull from user space or module
Hi @malj
You can refer to this series of patches. Although they are based on the i.MX8MM, the approach is similar for the i.MX6ULL.
https://patchew.org/linux/[email protected]/20220210084335.1979778-3-jian....
Zhiming
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎12-12-2025 03:36 AM
更新者:
