2253600_en-US
2253600_en-US
2253600_en-US
Pin mux difference between Processor Expert and S32DS 3,6,2 'Pin tool'
I am porting a project for S32K148 that was created on S32DS for ARM v 2.2 with Processor Expert. When I assign pins to the peripherals, e.g. the ADCs, I find that the pin numbers are different between the older and the newer IDE. For example, ADC0 channel 0 is connected to pin 115 (PTA 0) with Processor Expert, whereas it is connected to pin 140 (also PTA 0) with the new IDE.
Is this difference to be expected or am I doing something wrong?
Re: Pin mux difference between Processor Expert and S32DS 3,6,2 'Pin tool'
Thank you, @Robin_Shen . That was indeed the issue.
Did you select the correct package by clicking Switch Package?
Robin
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎12-04-2025 02:44 AM
更新者:
