2198915_en-US
2198915_en-US
2198915_en-US
frdmrw612_fmstr_example_wifi
Import WIFI sample projects through the wizard. Do the following:
1.etwork_wifi.c Modify the AP SSID and password to build the project.
2. Use CMD to write image to flash, "loadbin D:NXP_V24frdmrw612_fmstr_example_wificomponentconn_fwloaderfw_binrw61x_sb_ble_15d4_combo_a2.bin,0x085e0000".
3. IDE debug project, after running, stay here.
I don't know what the problem is?屏幕截图 2025-11-05 170038.png屏幕截图 2025-11-05 170855.png
Re: frdmrw612_fmstr_example_wifi
Hello @MrShen, hope you are doing well.
Please notice that the firmware required by your Wi-Fi application is the one labeled as "rw61x_sb_wifi_a2.bin" in the same path (/components/conn_fwloader/fw_bin/), as stated in section 4.1.1 of the UM11799 - NXP Wi-Fi and Bluetooth Demo Applications for RW61x.
Please try the example after loading this firmware and let me know if the issue is solved.
タグ(1)
評価なし
バージョン履歴
最終更新日:
‎11-21-2025 05:30 PM
更新者:
