We have obtained the FMEDA for the S32K312. We would like to know if, when we need to modify the configuration based on our own application but without the Medini tool, would NXP support us in making the modifications? What form of support would it be (through FAE? or a meeting? etc.)? What information do we need to provide? Thank you!
BRs
Apologies for the delay in our response.
Yes, we can provide customized FMEDAs based on your use case specifics.
We would need the following information:
1. Choice Mission Profile
2. Choice of package or exact part number
3. Choice of failure rate catalog (Default is IEC TR 62380)
4. Peripherals (including GPIO pins) to be considered safety related (Please refer the Safety Manual "Addendum" for the list of SR-AD or Safety Related Application Dependent peripherals which may or may not be a part of your application
5. System level measures (and their coverages) to be considered for the protection of peripherals (refer the safety manual for more details and recommendations)
Additionally, we would request you to kindly review the list of safety mechanisms and Assumptions of use (AoUs) mentioned in the safety manual, also required by our assumed safety concept. In case of any deviations in your use case ISO calls for a safety impact analysis to be performed by the party changing the list of applicable assumptions.
Hoping this helps!
Thanks!
-Yashwant
