2192154_en-US
2192154_en-US
2192154_en-US
rw612 ble gatt Server paring how to fixed passkey
rw612 -> gatt server   NoInputNoOutput
phone ->gatt client
ble paring,how to fixed rw612 passkey (for example 123456,Not a random value),phone input 123456 to pair rw612
Re: rw612 ble gatt Server paring how to fixed passkey
Hi @Christine_Li,
Thank you so much for the quick response! The patch you shared worked perfectly, and I’m now able to set the fixed PassKey successfully.
Hi, @Siddhesh_Nayak
Thanks for reaching me out.
I will share the patch with you through working email.
And for your information, I already report this issue to our internal SAE team, I think they are evaluating to include the patch in our future release.
Christine.
Hi @Christine_Li,
I am upgrading the SDK v25.09.00 from v2.15.00 in our MW.
I have noticed the same where in even If I set the CONFIG_BT_FIXED_PASSKEY and I call bt_passkey_set(FIXED_PASSKEY_VALUE).
the bt_conn_auth_cb.passkey_display callback gives me a random PassKey instead of the Fixed.
This was working perfectly with the SDK version v2.15.00.
Environment Details :
Board used: FRDM-RW612
SDK : v25.09.00
application : Custom Application.
Can you please help me out solve the issue?
Hi, @flybir
Thanks for your trying and let me know your result!
Can you please create a new case to track the new issue and mark my answer as a solution for this case?
We always recommend to track one issue with one case, so that we can provide a better reference for future cases.
And for your info, we always deal with the case with different priority level.
If you have a company email, please do not hesitate to create case with your company's email. It might increase the priority of your case.
If you don't have, please ignore my hints. And we will still continue to support you with current priority.
Christine.
Hi, @Christine_Li
Thanks for the reply, I have tried it and it works,follow the steps you provided,passkey is fiexd to 123456,
but a new problem arises: when finish bonding,I try to get Battery Service,it is not work and rw612 shell seems not work.
Please take a look at my log to see if there are any problems, thanks for any help.
@bt> bt.init
@bt> Bluetooth initialized
Settings Loaded
       29224: DEBUG bt_pal_smp.c:9449:LE SC enabled
@bt> bt.advertise on
Advertising started
@bt> bt.auth display
@bt> bt.fixed-passkey 123456
----func: cmd_fixed_passkey, line: 4347-------
@bt> ----func: cmd_fixed_passkey, line: 4368--passkey 123456-----
@bt> BLE Connected: 44:BD:E2:B9:92:FD (random)
       58269: DEBUG bt_pal_smp.c:7164:conn 200273BC handle 128
       58269: DEBUG bt_pal_smp.c:5436:chan 2002948C cid 0x0006
44:BD:E2:B9:92:FD (random)@bt> LE data len updated: TX (len: 251 time: 2120) RX (len: 27 time: 328)
LE conn  param req: int (0x0006, 0x0006) lat 0 to 500
LE PHY updated: TX PHY LE 1M, RX PHY LE 1M
LE conn param updated: int 0x0006 lat 0 to 500
LE conn  param req: int (0x0018, 0x0018) lat 0 to 500
LE conn param updated: int 0x0018 lat 0 to 500
LE PHY updated: TX PHY LE 2M, RX PHY LE 2M
LE data len updated: TX (len: 251 time: 2120) RX (len: 27 time: 2120)
Confirm pairing for 44:BD:E2:B9:92:FD (random)
       75262: DEBUG bt_pal_smp.c:9303:event 2
       75262: DEBUG bt_pal_smp.c:9321:RX queue put buf 20029708
       75262: DEBUG bt_pal_smp.c:8515:SMP event =  SMP_AUTHENTICATION_REQUEST, status 0
       75262: DEBUG bt_pal_smp.c:8535:conn = 0x200273BC
       75262: DEBUG bt_pal_smp.c:8812:Recvd SMP_AUTHENTICATION_REQUEST
       75262: DEBUG bt_pal_smp.c:8824:Bonding type : Bonding
44:BD:E2:B9:92:FD (random)@bt> bt.auth-pairing-confirm
44:BD:E2:B9:92:FD (random)@bt> Passkey for 44:BD:E2:B9:92:FD (random): 123456
       81122: DEBUG bt_pal_smp.c:9303:event 4
       81122: DEBUG bt_pal_smp.c:9321:RX queue put buf 20029708
       81122: DEBUG bt_pal_smp.c:8515:SMP event =  SMP_PASSKEY_DISPLAY_REQUEST, status 0
       81122: DEBUG bt_pal_smp.c:8535:conn = 0x200273BC
       81122: DEBUG bt_pal_smp.c:8946:Event   : SMP_PASSKEY_DISPLAY_REQUEST
       81122: DEBUG bt_pal_smp.c:8947:BD Address : FD 92 B9 E2 BD 44
       88372: DEBUG bt_pal_smp.c:9303:event 6
       88372: DEBUG bt_pal_smp.c:9321:RX queue put buf 20029708
       88373: DEBUG bt_pal_smp.c:8515:SMP event =  SMP_KEY_EXCHANGE_INFO_REQUEST, status 0
       88373: DEBUG bt_pal_smp.c:8535:conn = 0x200273BC
       88373: DEBUG bt_pal_smp.c:8965:Event   : SMP_KEY_EXCHANGE_INFO_REQUEST
       88373: DEBUG bt_pal_smp.c:8966:BD Address : FD 92 B9 E2 BD 44
Hi, @flybir
Yes, I send it again just now.
Please check your email and let me know whether you received the patch, and whether this patch works on your side.
Christine.
Hi, @Christine_Li
    Thanks for the reply, I did not receive the patch you shared to me by email.
    Did you send to the  [email protected] ?
Hi @flybir
Have you already added the patch I shared to you by email?
If no, please firstly add the patch, then have a try.
Thanks!
From your shared log, I see below:
The passkey doesn't fixed to 123456, it is showing: 047307 is your passkey.
I guess you didn't add my patch shared to you by email.
88617: DEBUG bt_pal_smp.c:8824:Bonding type : Bonding
49:7B:58:F5:35:CA (random)@bt> Passkey for 49:7B:58:F5:35:CA (random): 047307
Christine.
Hi, @Christine_Li
    Thanks for the reply, I have tried it and it still didn't work,follow the steps you provided,passkey is still not fiexd to 123456;
    The FW image I have used provided by the directory:  /components/conn_fwloader/fw_bin/rw61x_sb_ble_a2.bin
/************************************************ENABLE DEBUG LOG *************************************/
@bt> bt.init
Settings Loaded
        6065: DEBUG bt_pal_smp.c:9449:LE SC enabled
Advertising started
BLE Connected: 49:7B:58:F5:35:CA (random)
81457: DEBUG bt_pal_smp.c:7164:conn 200273BC handle 128
81457: DEBUG bt_pal_smp.c:5436:chan 2002948C cid 0x0006
49:7B:58:F5:35:CA (random)@bt> LE data len updated: TX (len: 251 time: 2120) RX (len: 27 time: 328)
Confirm pairing for 49:7B:58:F5:35:CA (random)
88617: DEBUG bt_pal_smp.c:9303:event 2
88617: DEBUG bt_pal_smp.c:9321:RX queue put buf 20029708
88617: DEBUG bt_pal_smp.c:8515:SMP event =  SMP_AUTHENTICATION_REQUEST, status 0
88617: DEBUG bt_pal_smp.c:8535:conn = 0x200273BC
88617: DEBUG bt_pal_smp.c:8812:Recvd SMP_AUTHENTICATION_REQUEST
94322: DEBUG bt_pal_smp.c:9303:event 4
94322: DEBUG bt_pal_smp.c:9321:RX queue put buf 20029708
94322: DEBUG bt_pal_smp.c:8515:SMP event =  SMP_PASSKEY_DISPLAY_REQUEST, status 0
94322: DEBUG bt_pal_smp.c:8535:conn = 0x200273BC
94322: DEBUG bt_pal_smp.c:8946:Event   : SMP_PASSKEY_DISPLAY_REQUEST
94322: DEBUG bt_pal_smp.c:8947:BD Address : CA 35 F5 58 7B 49
Pairing failed with 49:7B:58:F5:35:CA (random) reason: Authentication requirements (4)
Security failed: 49:7B:58:F5:35:CA (random) level 1 reason: Authentication failure (1)
106742: DEBUG bt_pal_smp.c:9303:event 1
106742: DEBUG bt_pal_smp.c:9321:RX queue put buf 20029708
106742: DEBUG bt_pal_smp.c:8515:SMP event =  SMP_AUTHENTICATION_COMPLETE, status 1028
106742: DEBUG bt_pal_smp.c:8535:conn = 0x200273BC
Bond deleted for 49:7B:58:F5:35:CA (random), id 0
Disconnected: 49:7B:58:F5:35:CA (random) (reason 0x13)
109800: DEBUG bt_pal_smp.c:5452:chan 2002948C cid 0x0006
@bt>
Hi, @flybir
I already tested it locally, and it can work on my side.
Please see attachment for my test logs.
Christine.
Hi, @flybir
Firstly add the patch I shared to you by email, then test with below steps.
Please let me know whether it works for you.
If it does work, please do not hesitate to mark my answer as a solution for this case.
Thanks!
Please have a try with below steps:
Test process (RW61x as slave,phone with nrf app as master):
1/ bt.init
2/ bt.advertise on
3/ bt.auth display
4/ bt.fixed-passkey 123456
5/ nrf app connect redfinch
6/ nrf app bond
7/ bt.auth-pairing-confirm
8/ nrf app input passkey 123456
Christine.
Hi, @Christine_Li
  Thanks for the reply, I have tried it and it didn't work, When my phone is paired with the RW612, I don't need to enter any passkey.
SHELL build: Oct 24 2025
Copynight  2020  NXP
@bt> bt.init
Settings Loaded
Advertising started
@bt> BLE Connected: 78:7B:E1:EC:D5:AC(random)
Hi, @flybir
Yes, you are right.
I checked  and found that this API isn't called by anywhere.
You might need to call it by referring this example: edgefast_bluetooth_shell.
In this example, it calls this API bt_passkey_set();
And please remember enable this Macro:
#define CONFIG_BT_FIXED_PASSKEY 1
is also needed.
Please see below for my test logs, hope it can help you.
Christine:enter cmd_fixed_passkey!
@bt> Christine:fixed_passkey is: (passkey 123456)
Setting fixed passkey failed (err 0)
Christine.
Hi, @flybir
Thanks for your quick reply.
Let me check it further, then share with you.
Christine.
Hi, @Christine_Li
  Thanks for the reply, I have tried it and it didn't work.
Hi, @flybir
Can you please have a try with below Macro in edgefast_bluetooth_config.h
Christine.
Are you using FRDM-RW612? YES
What's your MCUXpresso IDE version? v25.6
SDK version? FRDM-RW612 25.06.00
which example you are using?  frdmrw612_wireless_uart
I want the Bluetooth pairing code of the RW612 to be fixed to 123456, and the phone can be paired with the RW612 with a fixed pairing code.
I have tryed bt_passkey_set(123456)  not work.
Thanks for any help!
Hi, @flybir
What's your MCUXpresso IDE version? SDK version? and which example you are using?
Please let me know more backgrounds of your question, so that I can check further for you.
Christine.
Re: rw612 ble gatt Server paring how to fixed passkeyThanks for any helpRe: rw612 ble gatt Server paring how to fixed passkey
Hi @Christine_Li ,
I'm facing the same issue mentioned above. Could you please share the patch with me.
My email is: [email protected].
Please also CC: [email protected]
Hi, @saidalghabra
Sorry for my late reply.
For this request, can you please help to create a new case to us?
We are not allowed to share the patch  to anyone except have case tracking and company's system reviewing/verifying.
And also, please let me know which chipset you are using and your SDK version.
Thanks for your corporations!
Christine.
No ratings
Version history
Last update:
‎03-12-2026 02:34 AM
Updated by:
