2169694_en-US
2169694_en-US
2169694_en-US
SECURE BOOT :The calculation results of GMAC are all zeros.
Currently, the secure boot function is under development.
The GMAC KEY has been imported into the NVM KEY Catalog, with KF set to HSE_KF_USAGE_SIGN.
The GMAC calculation has not reported any errors, but the results are all zeros.
What could be the reason for this?
Re: SECURE BOOT :The calculation results of GMAC are all zeros.
Hi @LISI1
This sounds like data cache issue. Be aware that all data objects used for communication with HSE must be forced to non-cacheable memory because HSE can’t see core’s cache. For quick test, you can try to disable data cache in your project to see if it makes a difference.
It's mentioned in the integration manual:
Lukas
标记 (1)
无评分
版本历史
最后更新:
‎11-21-2025 11:33 PM
更新人:
